This time you have AMD it won't be. Last time i had AMD was running ME, so i don't think that's comparable. But AMD processors are a lot better than they used to be, surpassing even Intel in some respects.
Product Name Qty Price Line Total
Sapphire ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card Sapphire ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card £198.98
(£173.03) £198.98
(£173.03)
Dell UltraSharp 2209WA 22" Widescreen LCD Monitor Dell UltraSharp 2209WA 22" Widescreen LCD Monitor £194.99
(£169.56) £194.99
(£169.56)
AMD Phenom II X3 Tri Core 720 Black Edition 2.80GHz (Socket AM3) - Retail AMD Phenom II X3 Tri Core 720 Black Edition 2.80GHz (Socket AM3) - Retail £92.99
(£80.86) £92.99
(£80.86)
Asus M4A785TD-V Evo AMD 785G (Socket AM3) PCI-Express DDR3 Motherboard Asus M4A785TD-V Evo AMD 785G (Socket AM3) PCI-Express DDR3 Motherboard £70.99
(£61.73) £70.99
(£61.73)
G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (F3-12800CL8D-4GBRM) G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (F3-12800CL8D-4GBRM) £67.99
(£59.12) £67.99
(£59.12)
Be Quiet! Straight Power 650W ATX2.2 SLi Compliant Power Supply Be Quiet! Straight Power 650W ATX2.2 SLi Compliant Power Supply £66.99
(£58.25) £66.99
(£58.25)
NZXT BETA Classic Series Case - Black (No PSU) NZXT BETA Classic Series Case - Black (No PSU) £39.99
(£34.77) £39.99
(£34.77)
Sony Optiarc AD-7241S 24x DVD±RW SATA Lightscribe Optical Drive (Black) - OEM Sony Optiarc AD-7241S 24x DVD±RW SATA Lightscribe Optical Drive (Black) - OEM £18.99
(£16.51) £18.99
(£16.51)
Coolermaster Hyper TX3 CPU Cooler (Socket 754/939/940/AM2/AM3/775/1156) Coolermaster Hyper TX3 CPU Cooler (Socket 754/939/940/AM2/AM3/775/1156) £13.98
(£12.16) £13.98
(£12.16)
Sub Total : £665.99
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £15.50
VAT is being charged at 15% VAT : £102.22
Total : £783.71
my plan has changed a little.
i already got antec sonata and 900, sonata is being unused, so i will transfer all hardware from 900 to sonata and use it as download box and file server. will use 900 case for new system. i will use the DVD-RW from 900 instead.
how about this spec?
Go with this but change the case to a Antec 300 Three Hundred Ultimate Gaming Case http://www.overclockers.co.uk/showproduct.php?prodid=CA-101-AN&groupid=701&catid=7&subcat= works out £6 more but well worth it!!!!!!!!!!!
Nah, i much prefer the NZXT Beta...
Here is my i5 spec:
Its a bit over budget, but it is worth it. If you need to get it down to £750 then switch to an AMD X3 720BE or X4 955 AM3 system (i would be happy to spec you one up). I suggest sticking with the GPU I chose, have a look at this review (Green Bar). It seems to give the GTX285 a kicking.
Oh, the monitor I chose is well worth the premium. Being an eIPS panel and all.
Micro-ATXYou do realise that, that mobo you have selected here, is a Micro-ITX one yes?
how about this one? my budget is up to £750
i would like to have VT(virturalization Technology) supported as i use vmware a lot
