spec me a best gaming system for £750 - 2 hours left to click 'buy' button
2 Sep 2009
cmndr andi's spec looks good to me. I would go with that if you have your heart set on intel. Anyway good luck with it mate, you wont have any problems running any games for the next few years. :)
15 Sep 2009
I wouldnt base that machine on VMWare, why dont you buy a decent gaming machine and a cheap HP tower server Quad Core Xeon/AMD (they all have VT and do the job much better) for VMWare, you also might want to have a go with Citrix Xenserver (which is free also)!
Thats what I did last year and stupidly sold both (I know i know), you can pick up some decent servers at little cost for what you want right here:
http://www.serversdirect.co.uk/HP_P...n_1354_2.2_GHz_470065-138/version.asp?PID=768
EDIT: You'll need more RAM but for that server, its cheap as chips!
17 Mar 2009
Nottingham
My stab at a spec
Mobo support sli and crossfire which i assume by one fo your comments you wanted.
3 Jul 2007
Rochdale/whitworth
Product Name Qty Price Line Total
Sapphire ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card Sapphire ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card £198.98
(£173.03) £198.98
(£173.03)
Dell UltraSharp 2209WA 22" Widescreen LCD Monitor Dell UltraSharp 2209WA 22" Widescreen LCD Monitor £194.99
(£169.56) £194.99
(£169.56)
AMD Phenom II X3 Tri Core 720 Black Edition 2.80GHz (Socket AM3) - Retail AMD Phenom II X3 Tri Core 720 Black Edition 2.80GHz (Socket AM3) - Retail £92.99
(£80.86) £92.99
(£80.86)
Asus M4A785TD-V Evo AMD 785G (Socket AM3) PCI-Express DDR3 Motherboard Asus M4A785TD-V Evo AMD 785G (Socket AM3) PCI-Express DDR3 Motherboard £70.99
(£61.73) £70.99
(£61.73)
G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (F3-12800CL8D-4GBRM) G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (F3-12800CL8D-4GBRM) £67.99
(£59.12) £67.99
(£59.12)
Be Quiet! Straight Power 650W ATX2.2 SLi Compliant Power Supply Be Quiet! Straight Power 650W ATX2.2 SLi Compliant Power Supply £66.99
(£58.25) £66.99
(£58.25)
NZXT BETA Classic Series Case - Black (No PSU) NZXT BETA Classic Series Case - Black (No PSU) £39.99
(£34.77) £39.99
(£34.77)
Sony Optiarc AD-7241S 24x DVD±RW SATA Lightscribe Optical Drive (Black) - OEM Sony Optiarc AD-7241S 24x DVD±RW SATA Lightscribe Optical Drive (Black) - OEM £18.99
(£16.51) £18.99
(£16.51)
Coolermaster Hyper TX3 CPU Cooler (Socket 754/939/940/AM2/AM3/775/1156) Coolermaster Hyper TX3 CPU Cooler (Socket 754/939/940/AM2/AM3/775/1156) £13.98
(£12.16) £13.98
(£12.16)
Sub Total : £665.99
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £15.50
VAT is being charged at 15% VAT : £102.22
Total : £783.71
Go with this but change the case to a Antec 300 Three Hundred Ultimate Gaming Case http://www.overclockers.co.uk/showproduct.php?prodid=CA-101-AN&groupid=701&catid=7&subcat= works out £6 more but well worth it!!!!!!!!!!!;);):cool:
30 May 2009
Maidenhead
my plan has changed a little.
i already got antec sonata and 900, sonata is being unused, so i will transfer all hardware from 900 to sonata and use it as download box and file server. will use 900 case for new system. i will use the DVD-RW from 900 instead.
how about this spec?
You do realise that, that mobo you have selected here, is a Micro-ITX one yes?
18 Jun 2009
Kent
Here is my i5 spec:
Its a bit over budget, but it is worth it. If you need to get it down to £750 then switch to an AMD X3 720BE or X4 955 AM3 system (i would be happy to spec you one up). I suggest sticking with the GPU I chose, have a look at this review (Green Bar). It seems to give the GTX285 a kicking.
Oh, the monitor I chose is well worth the premium. Being an eIPS panel and all.
+1 this one. Enormous value there.
If you must you could save a few quid on the monitor. 4gb Ram and a i5 750 is a far better deal.
29 Aug 2004
Glasgow
how about this one? my budget is up to £750
i would like to have VT(virturalization Technology) supported as i use vmware a lot
I like ths one.
What's the point in showing systems that are over the £750 limit?
I would recommend you get the basics right. Mobo, PSU and case. Everything else can be easily upgraded.
