I'm A Bit Stuck...
24 Aug 2009
Hey, I've waited for the 5870's to come out and had a look at benchmarks and reviews, and I think they are fantastic. However, I am stuck between the 5870 or gtx 295, I will be planning on crossfireing the 5870 and if i got the gtx 295, i would sli that. But is it worth it tho, £50 dearer and only little fps? I will be purchsing either a 5870 or a gtx 295 by october 20th, just need a bit of help deciding :) I think i might go for the 5870.
28 May 2007
Crossfire 5870 will be faster than quad sli gtx295 so in the long run your machine will be faster taking the 5870 route. The 5870 route will also be cheaper. Also the 5870 has dx11 so if you are not planning a gpu change soon you would be mad to get a gtx295 as when the dx11 games come out you won't be able to use dx11 with the gtx295.
OP
24 Aug 2009
If he has the money then why not? I would if i had the money and no one knows yet how these dx11 games are going to run.
Very true, im guessing for all of the fantastic graphics and aa new levels etc you would need monster cards to run them but yeah i think im gnna go for the 5870 :) thx guys
