- 4 Aug 2009
- Thornton, Lancashire
like it PaulyD! V Nice!!
			mrk, Shilz.... Please don't hurt me:
(my shopping list for pay day, I should end up with two identical systems next week)
ok here is my build a corsair 800 with corsair H50 cooler on a gigabyte X58 ud5 motherboard with 6 gig kingston hyperX + hyperx cooler for ram 3x EVGA gtx260 with a 1200w bequiet power supply
Great build, but you need to remove the silly case badges. COMPLETELY RUINS THE ELEGANCE OF A HIGH END CASE!!!!!!!!!! when will people learn????
http://img28.imageshack.us/img28/1012/donthurtme.jpg
 . Im also impressed with those Akasa cable ties, they're bloody strong when strapped up!
Its about the only way you can do it on a gigabyte because they have the 6/8 pin there especially with a bottem loading PSU. Its the same as mine although its higher up and made by ASUS.
Loved those abit boards. Had an AN7 a while back running a Athlon 3000+ OC'd to 2.8 Ghz and was stable and a ATi 9800 XT. Was an amazing system back in the day. I then found intel and nVidia
Yeah the abit ip35 pro is the best board Ive had, had no probs from the word go and cos the mem is well away from the cpu, theirs no wrorries of cpu coolers not fitting from the mem being in the way.
Spec in my sig; NZXT Blackline case.
ive got that case what colour fans are you using and what do you think of the case
 Get some blue LEDS in there to break it up.
