X key does a taunt
lol, it's normally her healing me.
Not sure what the button is if using k/b but the B button on the 360 pad calls her too you if she is out of range. Holding B brings up a pop up menu that changes their state between attack (run off like a loon smashing pots etc) and cover (sticks next to you quite often being useless while you're surrounded by enemies.)
Where can I get these fan hacks?
Cheers
I had this but dropping Cat AI back down to standard, from advanced, and setting the Avio video, all settings page, back to defaults seemed to fix it. That's with a 4870x2, maxed, at 1080p x4AA, Win7 Cat 9.9.
Could have been the restart that did it but I managed to watch the few cut scenes through the menu, that where black first time around and then continued my game and saw the next few cut scenes ok. Though I didn't play much further, so maybe it stops working again after a while.
.This works for a bit then stops as i still got blank cutscenes.Turning Cat AI off may work better but its like removing AA on the char as hes a little fuzzzy around the edges.
top this off with woeful lvl 3 performance on ati 9.8 and unable to pull off 60fps in dx 9 and im not happy
it seems every game nowadays has bugs as i cant even pull of a solid 60fps in arkham asylum either which doesnt look as pretty as res 5 imo.it keeps stuttering from 90 to 40 during fights which to me is poor coding.
mt rig should handle these games 60fps easily...
Core 2 2.8
4890
4gb ram
Horrible controls, I embarrassingly am struggling to get past the first mini-boss using a 360 controller. !
Complete the game once and if you have a weapon that is fully upgraded, you can then purchase the option for it to have unlimited ammo in the Bonus Features section and then enable it under Special Features. For the Rocket Launcher, you just need a total time of under 5 hours on any difficulty, so that means you can play any chapter in order to decrease the game time amount (Do speed runs with powerful weapons on Amature). Also the Grenade Launcher is the only weapon without the option of unlimited ammo.anyone got any cheats for unlimited ammo etc??
