CPU/MB/RAM for a s1156 system
12 Feb 2008
Shropshire
Hi, I'm looking at getting a s1156 system and I'm looking for some advice on what CPU/MB/RAM to get. Now I know I've already got a respectable system (see sig) but I'm looking for something new. I intend to sell on the main parts of my S775 system to help fund the upgrade. The most tasking thing the system will do is gaming. So far I've come up with this:
Would an i5 750 be enough for gaming? Would I benefit from using an i7 860? Now I'm going to need a heatsink as no where seems to stock the 1156 bracket for the Prolimatech Megahalems, any suggestions? If there is anything that needs changing then please feel free to say.
Thanks.
whats your budget?
the 750 and 860 perform well for gaming and the 860 performs better in benchmarks over the 750.
In order of gaming it goes i7 860>i7 920>i5 750
whats your budget?
Probably a max budget of £500 but more likely £450.
I use a UD5 with an 860 and 4GBs of G.Skill Ripjaw 12800C7 ram which works well together, the 3 components you have chosen are fine, the extra £60-£70 for an 860 over a 750 really depends on use, if you regularly use applications that can use HT (like video encoding software etc), then it is worth it...
Slight tweak of your selection. Swapped the Motherbaord for the MSI GD80 (approx £14 more)
the GD80 is getting VERY good reviews plus the OC Genie on the board will allow you to clock the 750 to 3.4-3.5ghz Stable with 1 press of a button on the Mobo.
Any suggestions for a heatsink guys? I do intend to use my Prolimatech when the bracket is eventually in stock but I'm going to need something in the mean time. How about the Scythe Ninja 2 http://www.overclockers.co.uk/showproduct.php?prodid=HS-024-SY&groupid=701&catid=57&subcat=1395 ?
Only thing I dislike about it is the push pin method of attaching it as it looks quite a big lump. Perhaps I should just get the retail i5 750 as that would have an adequate heatsink to run it at stock, just not sure how quiet it would be.
