4Gb of RAM. Only 3Gb Showing. Vista x64.
12 Sep 2003
Newcastle, UK
Hi all
Following on from this thread:-
http://forums.overclockers.co.uk/showthread.php?t=18060775
Task Manager says I only have 3Gb. Yet Windows System Settings says 4Gb and also CPU-Z says 4Gb.
However I noticed my \MAXMEM setting for Boot is also limited to 3Gb.
:confused:
I've checked in the BIOS (DFI Motherboard) for a Memory Remapping option but do not have one. The only thing I can see that is not DRAM timings is a Memory Hole 15M-16M option. Is this it?
Thanks all!
Hi all
:confused:
Thanks all!
Maximum Memory in Msconfig hasn't been enabled has it?
Hi
Yeah I have MaxMem set to 3328, it won't let me go higher. i.e. I can set 4096 which I thought I'd be able to. Is this what is causing the problem?
Everywhere I've looked shows the Memory Remap feature to be only on Asus boards. :(
Well I disabled that, and rebooted. Seems to have sorted it! :D :D :D
Task Manager now reports 4093Mb for Total.
I had no idea that option was to "limit" the amount of RAM. I thought it helped when the PC was booting?!
