*** Street Fighter IV League (Season 2) ***
no, it still says "Available, but not used" when the firewall is disabled. When the firewall was enabled and said UPnP was 'Not Available"
Sign me up please, main char = Akuma
reserve char = Gouken
I think my GFWLid is MikeHunt79, but I'll have to double check when I'm not using my netbook!
Also, howabout having knockouts for the top 4 finishers on points?
Character - Bison
GFWL - xDam0n
My stick is broke but im alright w/ keyboard.
Hi mate, there are only 16 places available in total, will do a count and go through the posts in awhile, it might be full. If not I will put you in.
e36 is this going to be a 2 character tourny or something?
You can select 2 characters if you wish, or stick to 1 throughout. If you select 2, you have the option of choosing your MAIN or RESERVE on your home game, but you must choose your MAIN in your away game. Just to add abit of variety but either way, before your game you will know both characters who your opponent can select. So if you fancy adding Dan or someone as your second after, go for it. ;)
RecD and MikeHunt79, sorry but it seems we are now full with 16 players! I have put you both down as reserves so if anyone drops out or doesn't show, I will put you guys in, I will also give you a good chance of getting in now...
REQUEST TO ALL PLAYERS: Please can you check the First Page, post 2;
http://forums.overclockers.co.uk/showpost.php?p=14997491&postcount=2
If there are any question marks next to your name, please can you tell me the relevant information I require. If you are sticking with 1 character please also tell me. I might have missed some info if you already mentioned it to me so please definately check the link above. You all have until Saturday 10th Oct to provide me with the relevant info I require, if someone has already vanished and question marks still remain next to their name, I will replace them with RecD and MikeHunt in that order. You have all been warned! :)
http://forums.overclockers.co.uk/showpost.php?p=14997505&postcount=4
Tips for video recording your games.
1. Make sure your using a seperate harddrive to record on that doesnt have the game on or windows on (something that isnt accesses when playing).
2. Make sure it is a fast hard drive, sata 2 or better and is defraged and smooth running.
3. When recording is finished you will need to compress it down from raw format. Since recording a game will be 2gig ish per home and 2gb per away game. Use windows movie maker. If your using win7 then it doesnt have it but you can get it from if you google for it like i did. Make sure you save it with a good bitrate so youtube can turn on HD mode which makes viewing all the more better for the others that are watching.
Here are my fraps settings. If its any help.
When recoding with windows movie maker or other, make sure the bitrate is 500kbps at the minimum (ideally you want 800+)
Note. I just tried video capture in xfire, it wasnt as smooth and 60fps like fraps was. Maybe codec issue i duno.
Not tried camstudio with sf4 yet.
What I was asking for earlier :D Cheers bud!
I forgot to mention if you do not have a decent i.e core 2 or quad at 3ghz or better then you might have trouble recording at 60fps with max details and res. You may need to turn your details or mainly res down. Also a decent gfx card helps for to play the game but im not 100% sure if the gfx card effects the recording process as much as cpu power and hdd speed.
Any news on the points system?
And how would it be decided who plays Home in the first match? I'd always want to play my Away game before my Home game.
Stop complicating things :p you up for afew games? I might sign on for abit.
ya sure, i haven't played you in a while.
and yea, i do seem to complicate things. such as my suggestion for a best for 3 for each home and away fixture, where each match would best a best of 3 or 5 :D
No problem, Sagat main and Sakura reserve so the option to use her is still there, that ok?
Yep - I love playing as Sakura because I like her mobility and moves, but I can only do it vs the computer. I get the stuffing kicked out of me online!
To keep things nice and simple, I have gone for what DreadNiK suggested.
Ok, so as before each round won gives the player a point, this way a close match which results in 3-2 is not the same as a 3-0... for the losing player. In the first instance he would get 2 points, in the second, no points.
In addition, the winning player receives a bonus point for the 'win'. That's it!
BTW, there's still quite afew ppl who have not posted to confirm their character choice, you have afew days left!
