Yup always in gear. Did it to my friends car the one time, even stated that I left it in gear, then she knocked down the wall![]()
Like this?
If people aren't taught to do it that way, why does that make them retarded? I wasn't taught to do it, nor do I drive a tractor, so I don't do it.
Isn't that illegal?![]()
I don't have a choice - I can't even take the key out unless it's in reverse.
Always leave it in either 1st or reverse depending which way im parked..
not really an issue because i always depress the clutch when starting up.. doesn't everyone![]()
What car's that? Seems a bit wackySurely you can then readjust the gear stick as you like once the key's out though?
A Saab, the ignition key is on the transmission tunnel. It's a bit like having a free multi-lock. Took a bit of while getting used to it, but I think it's a good idea, can't see why other manufacturers don't do the same.
