OCZ who own PC Power and Cooling have made the decision to no longer manufacture Power and Cooling PSU's.
They are focusing on the OCZ Z-Series PSU's as a replacement too these.
sauce? bad news if true. PC POWER & Cooling still lists 12 psu's in their range
The PC Power & Cooling silencers are rebadged Seasonics with crappy 80mm fans.
If you like them go direct and buy a Seasonic or another of their rebranded PSUs like the XFX or Corsair HX 650W and they have 120mm fans.![]()
Eureka! This is the M12D platform! Seasonic's latest and greatest. And it appears it's been tweaked to be even more awesome - you'll recall that my M12D 850 did not hold 12V ripple to such wonderfully low levels.
)That's so stupid, they made some of the best quality psu's out there. Hopefully the Z-Series can fill the void.
Err not quite true though is it? Yes, the oem who makes the psu for PCP&C are indeed Seasonic for this model but they make psu's for lots of people. Just the same as other oem.
It does not mean that it is "rebadged". Clearly from the review here:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=157
Yes, it is based on the same platform. Is the the same psu? No. It clearly outperforms the Seasonic by some margin so things must have being changed.
Never fall for the trap that because a certain oem makes psus that all the psus that oem makes are the same. They are built to the design and the components as specified be the retailer. PC Power & Cooling are renowned for specifying the best components such as Japanese caps etc.
Also throw in the fact that you get a 7 year warranty and it is cheaper than the so called "rebadged" Seasonic and you can see why people still want to buy them (so long as you can live with the noise though)
Most of the parts in the 910w Silencer are identical to the M12D 850W, both use the best components such as Japanese caps etc.
They have improved the ripple/noise from the already high standard of the M12D, but this not really a big selling point as it's not like you need that level of perfection in a PC.
But the high noise levels on the other hand are bad, and that's more of a concern for most people.
. 80mm straight through or 120mm with a 90 degree turn? I think I like the first idea more. I'm amused that so many people condemn them because they've used a smaller fan.
