Our run rate is still too low.
Aus need 89 runs at a run rate of less than 4.5, 8 wickets still in hand with 2 batsmen at the crease who have half centuries.Are you on drugs?Aus need 89 runs at a run rate of less than 4.5, 8 wickets still in hand with 2 batsmen at the crease who have half centuries.
New Zealand's run rate: 4.00. Australia's required run rate: 4.34. Australia's actual run rate: 3.78.
Run rate for the last few overs has been much higher, fortunately. Let's hope we can keep it up.
Yeah and run rate always tends to get higher towards the end of the innings.
You have won unless NZ bowl you out.Run rate for the last few overs has been much higher, fortunately. Let's hope we can keep it up.
Aus run rate in the last 5 overs: 5.60. Walk in the park!
Last 5 overs: 3.6.![]()
Yeah, and you've just lost a wicket. It's all over now![]()
Current odds at the bookies: Aus 1/33 NZ 10/1
Smile ffs![]()
50 runs needed from 13 overs!![]()
