- 30 Jan 2008
Yes, a gigabit card in the machine, an appropriate cable and a gigabit network hub.
I'll be very surprised if a duron box with onboard/minimal graphics card drew more than ~50W most of the time whilst it sits relatively idle.
Sorry for a slight hijack, but to obtain gigabit transfer speeds I just need a Gigabit connection to and from the homeserver right? (sorry if its a silly Q) lol... I been reading that Intels got the best Gigabit controller too?
.Intels are great, The Broadcom server range of PCI-E NIC's are fine too, that's what i've got in mine.
.Check the Home server pictures section. Mines the large one with 13 hot-swap bays.
Would I be able to stream HD movies wirelessly at all? Or should I plan to have this system wired to the media player?
built a home server that sits in my garage.
Old coolmaster case (free)
old tagan 400w psu (free)
E2140 - £25
Gigabyte P31 board (£20)
2gb of ram - £10
1.5tb hard drive - £65
So cost me just over £120 for it all. Also took XP off my main pc (running win7 beta) and installed xp on my server. Works fine. easy to configure and pretty easy to expand in the future and no noise as it's in the garage.
All transfer via cat5e to main pc/laptop/htpc in lounge via gigabit router.
Loads of bit and bobs around the member market for cheap server builds. No need for anything fancy - old cpu/boards will do just fine
I only have virus protection on my PCs.
I don't do anything (stupid) that would result in my PCs getting infected. It must work because I've only ever had one virus and that was about 10 years ago.
(i.e; certain write only access etc?)
