Terrible speeds on Entanet
8 Jul 2004
Le Norfolk
Hi, anyone else using Entanet and finding that after say 2pm the speeds drop considerably.
I'm sync'd at 8128kbps and have a line profile of 7000kbps and up to mid afternoon I am seeing perfectly acceptable results, however through the evening and night I can't get anything above 2mb!!
Now I know Internet traffic at these times increase 10 fold but Its only recently started happening.
Entanet traffic shaping now?
Traffic Management
In order to deliver an acceptable quality of broadband service to all users, Entanet manages the transfer of traffic across its network by utilising the Anti-Loss Tool, or ALT.
What is the ALT (Anti-Loss Tool)?
The ALT is an innovative tool that was created by Entanet to maximise performance for all users and to ensure latency and packet loss is kept to a minimum at times of stress on the network. Whereas other providers control and restrict several key protocols, Entanet believes that it is not for the provider to decide which traffic is a priority for the individual user. As such the ALT still allows end users to utilise their connection for their required purposes.
How does ALT work?
The ALT operates on a per interconnect basis, with each interconnect having a different limit of bandwidth capacity. As usage approaches these bandwidth limits, typically at between 95-99% of capacity, the speed of all connected users is initially reduced by 10%. Thereafter the ALT continues to sample data and, if necessary, reduces connection speed in increments of 300Kbps every minute until the bandwidth demand stabilises. These reductions are first applied to connections with the highest synch speeds, encompassing lower synch speeds as the incremental reductions are made. The reduced speeds then remain in place until sufficient spare capacity becomes available. At this point the ALT increases throughput in increments of 100Kbps every minute to ensure stable bandwidth availability.
Please note:
1. The maximum capacity available at each interconnect will not be published
as this is commercially sensitive information.
2. The Kbps increments and frequency of alteration are subject to change.
Marking high bandwidth users
Entanet monitors the interconnects on a 24/7 basis, taking 10 minute samples of radius accounting data. Data taken at times when the ALT is in operation on an interconnect up to midnight is then accumulated. From this data the top 2% of bandwidth users on that interconnect will be marked on our systems. If a user is marked 5 times, then an alternative set of rules will apply to this individual user's connection when the ALT is next in operation until they have not been marked for a period of 14 days.
Marked users' speeds will be reduced as per the standard rules of the ALT as described above. However, speeds will be reduced by an additional 100Kbps. To remove any mark those customers must remain out of the top 2% of bandwidth users on their serving interconnect for 14 consecutive days.
At Entanet's http://noc.enta.net site (and in the near future on the e-billing site) all customers are able to see the status of their account. If they have been marked as a top 2% bandwidth user on their serving interconnect this information will be clearly displayed on their account.
Please note: The above information is subject to change.
Alt kicking in?
Which node are you on?
Yeah, there is an outburst on the ADSL24 forums (since last month). People getting under a meg etc (when ALT was reported as off). They are throttling anyway. Either that or they reduced capacity by nearly half.
Router stats
ADSL Link
Downstream / 8128 kbps / Line Attenuation 36.0 db / SNR 7.1db
Upstream / 448 kbps / Line Attenuation 19.5db / SNR 20.0db
Wow, we only got the connection live on the 5th October.
I had noticed some slow down today but thought nothing of it, just been on Speedtest.net and its showing 400kb/s dl rate.. its usualy 800+ :(
I don't really like speedtest for accurate results these days. It said i was only getting a 2mb connection but my torrents were maxxing out at 700kb (on the dire o2 access package aswell). I don't mind the speed decrease i'll get on Entanet (if it happens) as the pings always seem to be great anyway. Can't complain with that since the line is for gaming. :P
I got these bt speedtester results at 7am this morning. It will be less then 2mb after midday
Download speedachieved during the test was - 6618 Kbps
For your connection, the acceptable range of speeds is 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Hey,
Can anyone link me to a basic overview/FAQ about how the Entanet network is structured, and how it operates please?
Cheers!
Su
Having same issues with ADSL24 - they say there isnt a problem!! but I think a drop from 7Meg to 1.5 is not acceptable! - how do I find out which node I am connecting through?
Go to http://www.entachoice.org.uk/central-checker/ and stick your router login into the box, that will then give you the node you're on.
There is an RSS feed from Enta themselves that gives more info but I don't have the link to hand.
Thanks, is there any way to change the node you are on - ie does it select each time you login in or is it the same?
