http://www.anandtech.com/video/showdoc.aspx?i=3643&p=24
2560x1600
5870 102 fps
285 = 85 fps
1680x1050
5870 = 204 fps
285 = 165 fps
Those results are bearing in mind also the drop in fps or 'Physx hit' so are doubly impressive.
2560x1600
5870 102 fps
285 = 85 fps
1680x1050
5870 = 204 fps
285 = 165 fps
Depends on ambient temperature and other temps, humidity, etc.
Nope as it moves around on the way up then moves straight down even tho there are fans behind.
If your gonna be pickythey aren't exactly fast moving fans - they wouldn't alone be producing enough airflow to move the steam at all unless it was very close to the vanes (which makes them kinda useless).
It is a bit odd... to skip a lot of science the steam would have to have a higher density/lower temperature than the surrounding environment to sink like that, so it wouldn't kick up so much when disturbed...
Its still much nicer tho than any smoke/steam I've seen to date.
I agree It looks a bit naff.Far too many small fragments & it blows out like explosives & not a body hitting it.
For a (human) body to do that kinda damage to that kinda wall it would have to have massive amounts of kinetic energy... the demo isn't supposed to be taken literal the ragdolls are just representative of objects hitting a wall.
