 - 28 Jan 2008
How the heck do you get sound? Is it possible out of PC speakers?
			hmmm, if it is 5.1 there should be one somewhere, that is the problem with these stupid "PC soundsystems", much better with a propper amp and speakers.
But I suspect there may be one on the back of the PC in the soundcard as it sounds like it is soem kind of all in one job.
Another way would be to connect HDMI to TV and then use the optical out from the TV (monitor), but this is no good in your case as you have the output on the PS3 anyway.
The soundcard does have one, so is it possible to connect to that and get sound? and to the above comment. Yes it has speakers, but I have a brilliant 5.1 system versus puny pc speakers.
Another option that may be easier, i have some expensive sony headphones (nice) How could I get sound out of them?
