Think this is too hard for me, I can't even get to the SAM sites on the first mission (I want to get the chopper achievement).
I've no idea what orders to issue or anything. Think I'm doing really well then my team just get killed.
Operation Flashpoint was never this hard :/
I struggled the first few missions, you just have to use trial and error, play through on normal first to get used to the game.
Some things that I stick to which keep me safe are as follows.
When ever advancing forward to an objective/waypoint, get your map out, look around for high ground, take that route instead so you always have the upper hand.
When ever an enemy shows up on your radar at the top of your screen (red triangle), whip your map out to see how far they are.
As for squad, always have them doing the following when advancing on an enemy: Vee formation, Combat spread, Return fire...
This way, they won't shoot allowing you as the leader to get into position and fire first or they fire back the moment you get spotted.
Do NOT sit in the same position, if you sat long enough to empty a clip, you are lucky to be alive... several shots, move to a better position...
don't bother ordering your squad to do something unless its to assault a building, fast move to extraction or heal you/team mates. They are useless at flanking. Do it your self.
Don't bother will fully auto fire (press right on d-pad to change fire rate)... Have single fire. Only auto when within 50m or sneaking up.
crouch and sprint when near enemy (within 400m) otherwise they will spot you a lot quicker.
Stick to tree lines and bushes... Stay clear of open ground.
When you see a building you need to take ahead... you guessed it, look at possible options of going round it then attacking from the back at it's weakest point.
Again, trial and error.
ags
