- 4 Jan 2004
- ¯\_(ツ)_/¯
Ignoring the safety thing for now, LiPo is nice because you can charge it very quickly, unfortunately the capacity goes down over time, and after a few years it's less than half!Will we be seeing LiPo Battery tech in cars? LiPo Batteries are normally a lot lighter than NiMh equivalents. LiPo is slightly more volatile, they do go up well![]()
They're trying to fix this problem right now...Imagine if your car had a range of 200 miles right now, how much would it suck if in a few years you would struggle to do 40 miles!
I disagree, even if vehicles were around, what batteries would you use that last longer than 5 or even 10 years? Battery replacements are not cheap... Even Lead Acid cells are not free from problems despite lasting longer than other cell types...Battery tech is viable for most peoples daily needs, the problem is the vehicles available.
Lithium IonLithium iron is the big boy at the moment. Well until 2014 and NiMh with 30yr lifes are back on the market for 'Vehicular use'. The quoted energy densitys of any lithium chemistry still isnt that much higher when you see the production stuff.
Tom Hanks is still blasting around in his Rav4 EV.
NiMh even if they produce batteries that last 30 years, don't they still have problems with memory effects, therefore needing to be deep cycled? Don't they also self discharge in a similar way to crappy Lead Acid cells?
If I was going to have to spend thousands on a battery powered car, I'd insist on Lithium Ion cells, once they fix the capacity loss over time issues...
