Good evening, knowledgeable ladies & gentlemen (and miscellaneous other) of the forum.
My shiny new Saphhire HD5850 turned up today, which is great, but I can't quite seem to get it to work, which is not so great.
Before I RMA it I thought I'd ask you graphics worldly people if you can see if there is anything I've missed before I embarrass myself with returning a working card.
Brief PC specs:
PSU: Corsair TX650W
MB: Asus P5N-E SLI (Bios v1301)
CPU: Intel Core 2 Duo ([email protected])
Mem: 4GB
Problem description:
No POST. No beeps. Power is running through everything (lights on cards & MB light up as expected), all fans kick into life. But no sound and no output.
I still have my old 8800GTS which despite starting to fail (weird artefacts and lines) will allow my system to boot up when it is switched back in.
I have unplugged all extraneous powered devices within the case (such as hard drives, cd drives, extra case fans) just to eliminate them. I have also ensured that both 6pin power plugs are connected to the HD5850 card. The card is in the primary (x16) slot.
Am I missing something obvious here? Is there a known issue with this motherboard and recent graphics cards? etc
Thanks for your time in reading this, hope you can help.
Edit note:
OC have finished testing my card and it seems fine.
This seems to confirm that the Asus p5n-e board has some serious issues with the 5850.
Brief PC specs:
PSU: Corsair TX650W
Mem: 4GB
Edit note:
