Eyefinity on 3 1680x1050 monitors
26 Mar 2009
Essex
Ive read reviews saying Eyefinity works best on anything about 1920 resolution, but i dont fancy wasting my current monitor. Would a single 5870 be wasted on 3 1680x1050 monitors?
3 x 1050 monitors is still over 5MP, so no, I wouldn't think a 5870 is wasted.
Remember at least one panel requires DisplayPort or an *active* DisplayPort adapter (i.e. not a straigh-through connector).
5MP is 5million pixels, which is a lot for a graphics card to cope with, hence a 5870 would not be wasted.
Where can you get the Active DisplayPort adapter in the uk?
In your dreams, seems to be the answer at the moment. :-/
I'd love to buy a 5780, to upgrade my 260GTX, 3x1680x1050 setup, but there seem to be a range of hurdles to jump over... no Eyefinity support for XP, no TripleHead support if you want to avoid a displayport adapter, and no powered displayport adapters available even if you want to spend more money!
Apart from that it's fine. :-)
Andrew McP
been looking for options on a displayport monitor the P2210 at £230-240 being the only one that is really popping up.
are there any cheap obvious options I am missing, ideally 22" 1680x1050 ?
Nope cheapest being the p2210, its £205 direct from dell btw.
Still waiting on a finance agreement for 3 of em :D
Then theres the new NEC for £299, then its jumps to around £400+ Dells.
I think there may be some lenovas also but they seem to be hard to come by here.
any help regarding the above? have searched about and doesnt seem to be any single 5850 reviews with eyefinity
