Hey,
I smartly broke my Maxtor drive
It was in my case, with another case leaning up next to it on the floor (swapping out parts), so i walk past it and knock the second case into the 1st case and snap the plastic off where the sata cable connects.
If i put the plastic in the sata cable then put it on carefully the machine powers on, but then crashes after a while.
I bought it second hand off but it's still under warranty untill 2011.
My question is, is that under the warranty and as i bought it second hand - can i get a replacement?
someone may know
Thank you!
someone may know
Thank you!
