Any of you planning trips/seasons away?
Rocker technology seems to be hitting the mainstream this season, remains to be seen if its going to be a fad though...
Rocker is extremely important for kiteboarding and wakeboarding. Gives you more of a 'scoop' which gets you higher for tricks. Also makes it easier to nosepress on sliders. Makes landing easier on the knees a bit also. For snowboarding....humm...you take off differently so i cant see the point of it.
Speaking of which, Im specking a setup atm to shred at the trafford centre ski. Ive hardly snowboarded before, but i cant see it being too different. Rails are my goal.
2010 155cm K2 darkstar.
A few kiteboards are made in the same factory as burton, and they fall apart, so staying way from them.
speaking of helmets...which is the most comfy? On the water i use the Protec ace wake which is perfect as the inner part is hard+soft foam. you cant tell its there, and fits the oddest shapes of head (mine!). Ive seen nothing like it for snowboards. Very little for comfort in comparison. those 3d0 beanie's / helmets out yet?
