Mel its booting fron DOS, Win 7 does not get a look in,
you need to try again :0
a bootable usb flash drive unpack the file onto it change the bios to bbot from said usb drive aand all hdd/sdd to ide and it will work, change back after tge boot![]()
How can I find out what firmware my Crucial 64Gb M225 is using as looks like if it is 1571 then its a straight flash to 1819 but if its 1711 then I have to roll-it back to 1571 first before updating it to 1819.
http://forum.crucial.com/t5/Solid-S...y-what-frimware-is-currently-on-SSD/td-p/5957Crucial Forums said:It will not say on the SSD drive label you will need to plug it in.
When you run the firmware flasher it will tell you what firmware version is currently on the SSD before flashing proceeds.
(If you received your Crucial SSD in a small brown cardboard box then it's a good chance it will have v1571)
To find out within Windows see device manager screenshot.
Control panel > select device manager > expand disk drives > right click on the drive and select properties
> select details tab > select hardware lds from the drop down menu.
TRIM can be enabled in w7, but if the drivers and firmware don't support it, the command is ignored by the system.
http://blogs.msdn.com/e7/archive/2009/05/05/support-and-q-a-for-solid-state-drives-and.aspx#9594848
Im right in thinking i have read on these forums that the intel x25-m 80GB wont require a format when it comes to updating firmware for TRIM support... right?![]()
TRIM should reduce performance degregation over time.Hi,
i am currently using a 160gb intel g2.
I was wondering if TRIM will keep my drive at top performance? I ask because i have seen peoples benchmark results. A few i've seen i have noticed a dramatic drop in certain areas (especially after a months use, some numbers are nearly 40% lower, mostly in the writes section, but reads suffer a bit too). I was wondering if the TRIM is going to stop that.
Also in preparation for windows 7, i would like to know how i go about wiping my ssd to its original factory state before i install the new OS?
Thanks,
Phil.
Intel Trim may be here today!
http://www.intel.com/cd/corporate/pressroom/emea/fra/434654.htm. A small translation of key points that i read somewhere else..... Trim today, new tools, new performance.
Phil.
26 October 2009 2CV102HA This firmware revision supports the ATA Data Set Management Command “Trim”. Also, this firmware revision includes several continuous improvement optimizations that provide for increased write performance on 160GB drives.
