So new 360's come with no leads at all to connect it to a TV?
Do Elite's still come with the optical/analog audio dongle?
i got a comp cable with mine
Not that i'm using it though, straight into HDMI for mine.
Didnt get any cable (apart from power lol) or dongle with my jasper bought on the street a couple of weeks ago
DVD drives are trickier than you'd expect. They're keyed to the xbox 360 they come with, so just swapping in a new drive isn't sufficient. You also have to reprogram it to match the 360 it's going into.
Means a new optical drive comes out a little over £50 to get it done in a repair shop, I don't know if the reprogramming is something that can realistically be done at home for a lower cost.
They aren't, but as Aspect has found, the Opus chipset can be used. This gives a 65nm CPU, but still a 90nm GPU. It does run cooler but as I said before, the fundamental design of the Xbox 360 hasn't changed since day one and if thermal flexing occurs, a RRoD is possible.
They should all come with the basic component cable at least, weird yours had none.
So the Jasper is apparently much improved?
The newer machines come with a composite cable plus scart adapter only, similar to what the PS3 has always done.
I've never understood the logic of supplying a "next-gen" console that can't output HD out of the box.
Simple logic is MS make even more money. But I know where you're coming from.
glad to see the console is still noisy as ever.
Because people keep buying them?
