- 7 Feb 2004
Whats a good tool for this, spec in sig.
Thanks
Thanks
ATi Tool
Using ati tool, how long do or can i leave it?
However long you want and until you are happy your clocks are stable, or until yellow dots appear on the fur cube, that way you know the card is artifacting
With furmark i think if the card passes 3000seconds on the stability test its safe to assume its stable with whatever you throw at it
juts play games and see if you get crashes if not your fine and can overclock more
I wouldn't be too sure. You could be artifacting and you might not see it.
then does it matter? its like if that tree falls...does it affect you?
there's always a warranty if it gets worse
