- 13 Sep 2005
- Crewe,Cheshire
Ive just rung oc to put a hold on a overclocked bundle Intel core i7 4gig which i ordered yesterday as ive been reading the forums and a lot of people seem to prefer the Megahalems cooler over the noctua and from most reviews it seems to be a better choice.
Couple of questions tho before i actually amend my order because im slightly worried as I have never bought a cpu cooler with out all the fans etc before, always just came in a box ready to go. I dont fancy much blowing it all up
Noticed i need the clips to fit the fans which seems straight forward enough now just which fan/s i go for also will the fans both plug into the cpu fan sensor thing or do i not have to do this.
Noticed the spec for the Megahalems mentions fan speed of 800~1200rpm, would something like the Noctua NF-P12 with the voltage drop arrangement, or is there something else you could recomend also with running 4gig should i use 2 fans in a pull/push set up. Ideally I would like it to be as quiet as possible, will be fitting it inside my p182 case.
. Noticed i need the clips to fit the fans which seems straight forward enough now just which fan/s i go for also will the fans both plug into the cpu fan sensor thing or do i not have to do this.
