What 42" Telly?
28 Sep 2008
Britain
Between 500 and 700 notes, have seen the x10 which I've always seen as pretty good units.
Any other suggestions for this price range?
TIA
my G10 packed up after 6 weeks, am getting a replacement on Tuesday :(
Kept cutting out after 5 mins turned on with no sources.
Upto that point i was very pleased with the TV, Blu Ray etc amazing.
There's a lot of discussion on Avforums about its Standard Def picture quality, i find it far better than my old Panasonic TX60 32 LCD, but it might be worth having a read.
The media streaming function on the G15/V10 isn't a bad extra, doesn't stream HD content though and file formats are limited (although luckily everything I have plays ok).
Depends on the price difference really and if you'll use the extra features, plus I think the chassis is a little different (thinner?) on the G15.
The V10 gives you even more over the G series but again puts the price up more, it's never ending!
pretty sure the g10/15 are the same bar the viera cast function.
the v10 is lovely but the only differnce i can see is it has DCC .
They have different cases/chassis, check the pictures out on the Panasonic site. From the specs looks liek the G15 is a little thinner than the g10.
G10 Picture
G15 Picture
G10 also has 3 HDMI sockets whilst the others have 4
V10 also has a THX certified calibration mode which is quite handy as you can't change some settings on these models :(
Mine's on THX mode all the time :)
Forces overscan off mind you, doesn't bother me as I like to see the whole picture but some people don't like it.
Colours look good in the mode and I like the fact I know it'd be damn hard to get the settings any better as I hate fiddling with colours etc wondering if I've got it setup right :)
i couldnt find it :confused: where in the menu should i be looking ?
the only model i could find with THX is the Z series.
It's just one of the modes (you have a V series right?) in the main viewing modes options.
So you have cinema, game etc, one of them will be called THX.
I dont personally but we have them in the shop, i found it in the end tho, i had a play but the only difference i could see was it made the picture darker and removed som the pixelation on sd images.
i personaly prefer normal mode :)
It shouldn't make the picture darker, it sets the gamma to 2.2 (as you can't set the gamma on uk models, grrr) iirc and sets the colours to a THX approved calibration.
It doesn't touch the brightness settings, that's what the brightness setting it used for :)
Cheers , i dont tend to look that far into the details, as most of our customers would leave baffelled if we told them every thing :D
