Unigine DirectX11 benchmark
I happens both fullscreen and windowed. And also with all drivers. Now I'm using 9.10. I've already contacted OC customer service and I'm getting a new one when availability gets better.
Just asked to make sure that's all :)
I have had flickering on the benchmark when running the tropics one through direct x 10 with an hd 5870. Also a couple of days ago when I changed the resolution of games ie cod4, the picture was distorted and I had to turn the lcd off and on.
I am also having issues with tessalation when it`s turned on.
It seems to artifact... worse screen offendor is the first screen with windmill. The brickwork at the bottom is very noticable.
I had overclocked my HD5770, but it happens when i return to stock settings. Also have my i5 clocked, but returning to stock settings makes no difference.
Running with Win7 x64
Anyone else seeing this?
All settings maxed on my system, 2xaa 4xaa 8xaa
tessalation enabled on all tests. maximum settings.
Been using this for stability testing while overclocking my Asus 4890. Sig needs updating but only change is the GPU. All run at 1920x1200 full screen DX11 renderer on Win7 x64 RC, no other changes.
GPU - Core - Mem - FPS - Score - Vcore - Temp - %OC
3870 - 795 - 2402 - 19.1 - 482 - CCC
4890 - 850 - 3900 - 34.0 - 856 - 1.35
4890 - 950 - 4400 - 38.1 - 961 - CCC - 70 - 12.05
4890 - 950 - 4600 - 38.0 - 957 - 1.35 - 70 - 11.76
4890 - 975 - 4600 - 38.9 - 980 - 1.37 - 74 - 14.41
4890 - 1000 - 4400 - 39.5 - 995 - 1.40 - 78 - 16.17
Have put my original 3870 run in there for comparison, which was clocked using the Catalyst Control Centre.
Asus SmartDoctor was used to clock the 4890 apart from the 950/4400 run (marked CCC) which was done without the Asus software installed.
To all these people with high fps in the 60 range with high res even though you have tessellation turned on are sometimes problems with drivers.
I was running with tessellation on however the benchmark actually has not got it running, it is only switched on in the settings but not being used. Take screenshots of the dragon to show tessellation is on and post it.
I had to update my drivers and then it worked.
5770 Crossfire
Unigine
Heaven Demo v1.0
FPS: 66.7
Scores: 1597
Hardware
Binary: Windows 32bit Visual C++ 1500 Release Oct 22 2009
Operating system: Windows 7 (build 7600) 64bit
CPU model: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
CPU flags: 3807MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 HTT
GPU model: ATI Radeon HD 5700 Series 8.660.6.0 1024Mb
Settings
Render: direct3d11
Mode: 1680x1050 fullscreen
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 4x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Unigine Corp. © 2005-2009
5770 Crossfire
Unigine
Heaven Demo v1.0
FPS: 66.7
Scores: 1597
Hardware
Settings
Render: direct3d11
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 4x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
tessellation on or off?
Tessellation on although i just ran it again after clocking up my graphics cards and only got 44fps...?
My results seem to be really random.
as said above sometimes when u enable Tessellation it doesn't actually turn it on .
66.7 fps sounded high with Tessellation on for 2 5770.
MOOGLEYS could you try it with just the one 5770 please? i'm intrigued as to how good these cards are as i can't really afford a 5850 right now but if a single 5770 isn't terribly good i guess i'll have to save a little for the 5850.
Ive noticed a 20% increase in fps in the Heaven benchmark with the new drivers, im using 2 5870s. Managed 76 fps with 1680-1050 tess enabled 16 af and no aa. 124 fps with tess disabled.
Strange thing is ive noticed a decrease in performance using 3dmark Vantage, 10% loss from the old drivers. My scores seem pretty shocking with xfire tbh. I get around 19k-20k gpu scores, ive seen some 295s setups with 25k+. Anyone else with a similar setup finding different results?
Just wondered how peoples scores have varied with 9.11 drivers in Vantage and Heaven.
