New drivers HD 58xx and 57xx series
well i get 74.5 on FIXED benchmark with no AA and same with AA 4x and 8x...
also i ran the gpu at 1000mhz and the fps didn't go up.
Did you get this sorted as when I run Crysis Warhead Framebuffer benchmark the fps drop from no aa to 2 aa and then the fps result is the same for 2xaa, 4xaa, 8xaa. I know AA is working ok as in the uniengine benchmark it drops in line with settings changes of aax0, aa x 2, aa x 4, aa x8
nope, still not sorted. i think i need to wait for 9.12 drivers for full performance and fixes.
I did searches in google and didn't see anyone having this issue except for you and mine is having the same problem, I tried framebuffer version 0.29 and 0.32 and both did not drop fps when increased aa above x2, only dropped when went from no aa to x2 aa
