1 Nov 2009 at 22:21 #1 Happy Happy Soldato Joined 7 Jan 2008 Posts 7,117 Location Tunbridge Wells Hey, My Seagate external hard drive just broke, and I have not seen the type of screw used on the caddy before. Anybody know where I can by a bit for it? Last edited: 1 Nov 2009
1 Nov 2009 at 22:22 #2 SlyReaper SlyReaper Soldato Joined 26 Apr 2008 Posts 6,653 Location Bristol, Old Blighty That's torx isn't it?
1 Nov 2009 at 22:25 #3 Happy Happy Soldato OP Joined 7 Jan 2008 Posts 7,117 Location Tunbridge Wells It doesn't appear to be since my torx set is flat at the end. I've never seen it requiring a whole in the end
1 Nov 2009 at 22:27 #4 Spinal2k2 Spinal2k2 Associate Joined 18 Oct 2002 Posts 2,471 its one of the security type torx bits
1 Nov 2009 at 22:28 #5 Cybermyk Cybermyk Soldato Joined 31 May 2005 Posts 6,847 Location Peoples Republik of Teesside It's a secure torx, you can get sets of screwdriver bits with them in for a few quid.
1 Nov 2009 at 22:29 #6 PhillyDee PhillyDee Soldato Joined 12 Feb 2007 Posts 14,117 Location South Shields Hold on, is that definately 5 pointed? If its 6 its torx, and this set will do you: http://www.screwfix.com/prods/18983/Screwdriver-Bits/Security-Bits/Security-Bit-Set-33Pc If its the 5 point ones, then search for 5 point torx. Its a special, and will cost more! Last edited: 1 Nov 2009
1 Nov 2009 at 22:33 #7 MikeHunt79 MikeHunt79 Soldato Joined 4 Jan 2004 Posts 20,802 Location ¯\_(ツ)_/¯ hmm, looks like a torx bit, but it only has 5 points, as opposed to 6. I have a 100 piece bit set, and non of these are 5 pointed tho...
1 Nov 2009 at 22:36 #8 Happy Happy Soldato OP Joined 7 Jan 2008 Posts 7,117 Location Tunbridge Wells 100% 5 point with a pin in the centre VVV Last edited: 1 Nov 2009
1 Nov 2009 at 22:36 #9 Cybermyk Cybermyk Soldato Joined 31 May 2005 Posts 6,847 Location Peoples Republik of Teesside Hang on, isn't that a pentagram I would heed the warning tbh.
1 Nov 2009 at 23:03 #10 Happy Happy Soldato OP Joined 7 Jan 2008 Posts 7,117 Location Tunbridge Wells I can't find anything that isn't for stupid money :/
1 Nov 2009 at 23:05 #11 Makhaira Makhaira Soldato Joined 23 Nov 2007 Posts 4,994 Location Lancashire, UK Definitely a security torx. Going to a well known auction site and just putting in security torx gave me a shedload of cheap options, you might want to start there.
1 Nov 2009 at 23:07 #12 Happy Happy Soldato OP Joined 7 Jan 2008 Posts 7,117 Location Tunbridge Wells Will do thanks Here's a pic
1 Nov 2009 at 23:25 #13 Cybermyk Cybermyk Soldato Joined 31 May 2005 Posts 6,847 Location Peoples Republik of Teesside Look in automotive tools too.
1 Nov 2009 at 23:38 #14 kylew kylew Permabanned Joined 31 May 2007 Posts 10,721 Location Liverpool How about melting a biro under a flame, then stuffing it on to the screw head? I used this method to open my gamecube, worked pretty well in fact.
1 Nov 2009 at 23:42 #15 meghatronic meghatronic Soldato Joined 24 Nov 2002 Posts 16,379 Location 38.744281°N 104.846806°W Find a screw, hack off the top, glue top to screw with Krazy Glue. Or use some thin nosed pliers.
1 Nov 2009 at 23:57 #16 NightSt@lk3r NightSt@lk3r Soldato Joined 7 Dec 2005 Posts 8,010 Location Wiltshire I find these really easy to undo with a flat head screwdriver.
2 Nov 2009 at 00:01 #17 "andy" "andy" Soldato Joined 9 Jun 2005 Posts 13,985 NightSt@lk3r said: I find these really easy to undo with a flat head screwdriver. Click to expand... this then replace them with more common screws
2 Nov 2009 at 00:03 #18 Marine Iguana Marine Iguana Soldato Joined 25 Sep 2008 Posts 6,767 Location Orsett, Essex NightSt@lk3r said: I find these really easy to undo with a flat head screwdriver. Click to expand... +1 i have done this before
2 Nov 2009 at 02:04 #19 Puzzled Puzzled Soldato Joined 9 Jul 2003 Posts 9,642 NightSt@lk3r said: I find these really easy to undo with a flat head screwdriver. Click to expand... They also seem to be made out of cheese, so you'll probably need some new screws to replace them.
2 Nov 2009 at 07:28 #20 peige peige Soldato Joined 18 Oct 2002 Posts 3,714 Location Sussex Or the middle pibble breaks off when you try to use a screw driver and then your standard torx works.
