yes but i have had 100% same issues on all 3 profiles for 2 months now.Have you changed your profile? If it reconnects at 3dB, it sounds like it's been changed to the "for speed" profile.
i feel your pain ive been disconnected around 10 times in 30 mins peeing me right offHi!
I'm having issues too. Symptoms are:
Some webpages load slowly, or need clicky encouragement.
PSN disconnects frequently.
Friends list on PSN populates slowly, if at all.
Time outs when connecting to PSN.
Stuff like Demon's Souls online, no messages are appearing.
Full port forwarding in effect and WIRED to the PS3. Laptops and PC's are wireless though.
Its weird. I was ok for a while but its gone back to being awful again. My issue is, I have no idea how to troubleshoot, what stats to check.
Box I'm on is a DGN2000 with the DGTeam firmware.
Filter is on, I have just the one socket in the house. Many filters tried.
Issues started when my trusty old router got blown in a storm, tried the BeBox (just as bad) and bought the DGN2000 with the premise of Annex M.
Stats are:
System Up Time 1007:35:15
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN Static IP 28366 29769 0 5785 13246 00:31:35
LAN 10M/100M 33886817 18050228 0 511 422 1007:35:11
WLAN 11M/54M 98132567 99241439 0 899 566 1007:34:47
ADSL Link Downstream Upstream
Connection Speed 12612 kbps 2169 kbps
Line Attenuation 28.5 db 13.0 db
Noise Margin 5.7 db 2.8 db
my laptop which is wireless has the same issue also, im on Ethernet on desktop
,ive tried the master socket behind the main BT socket and changed filter etc.
Be always tell you when you having problems to unscrew the bottom of the master socket and plug directly in the socket,not sure why this makes a difference.It was losing sync even on the 9dB "for stability" profile?
If the issue is that you're losing sync, the minimum SNR margin Be will set for you isn't the best choice in the entire world.
It would if the issue if that you're losing ADSL sync.
,,,and what?
It's good advice. My point was what happened?
It eliminates your extension wiring (which should, legally, be wired into the faceplate at most). You'd see an increase in sync rate or SNR margin or both.
Before throwing money at the problem, you'd have been far better working out exactly what was happening and trying to identify what was at fault. Introducing new hardware means a) Be won't even support you as long as you're using it and b) you have no idea whether it's working, broken, causing a problem or anything.
So what happens when it disconnects - does the DSL light go out on the router, do you need to restart it, what happens to the ADSL stats you pasted before?
its well know Be thomson routers are rubbish for a start
ive done everything possible my end to fix the problem
sometimes all lights go out most of the time all lights stay on and the ethernet and wireless lights are flashing.
as for the stats ive never checked the stats when i have this problem networks for me are extremely weak and the number figures make no sense to me.
for a start like i said i dont want a BE router as i need a n series router for better wireless so i dont consider that a waste of money.That's neither here nor there. Be will only support you with the Be Box and you haven't yet shown that the router's to blame.
Evidently not. You haven't actually identified what's to blame.
That sounds like the router rebooting. Be should be able to send you a new router but you've already ordered one. If you'd said this at the start we'd have had a much shorter thread...
So either post before and after or compare the numbers. You're only interested in about 3 anyway.
