cant turn off Hibernation in vista 64
26 Jan 2009
West Midlands
i came accross some tweaks for my ssd and this was mentioned http://www.ocztechnologyforum.com/forum/showthread.php?t=47212
"Last but not least we can now turn off Hibernation. An easy and fast way of doing this is from cmd.exe
>Click Start, and then type cmd in the Start Search box.
> In the search results list, right-click Command Prompt or Cmd.exe, and then click Run as Administrator on the pop up contextual menu.
>If you are prompted by User Account Control (UAC) for permission, click Continue.
>At the command prompt, type the following command, and then press ENTER:
powercfg.exe -h off
>Type exit, and then press ENTER.
Job Done..this should free up a huge amount of room also on the SSD. "
but i have the classic menu in vista so i cant search. i have tried Start> Run Cmd then "powercfg.exe -h off" but doesnt work?
i have tried this way also http://www.mydigitallife.info/2007/10/25/how-to-turn-off-and-disable-hibernation-in-windows-vista/
using disk cleanup but i dont have the Hibernation file cleaner option to UN tick ?
might not help but have you tried cleanmgr /sageset (change set to run to set it going) in run Cmd
there might a box to tick/untick in there
