very nicebest tips i have for a moka pot / stove top are:
- boil the water before you put it in the base otherwise the pot gets too hot
- fill upto (not over) the pressure valve but don't expect all the water to be used.
- Use a medium to coarse grind, finer than cafeteria but much coarser than espresso. Too coarse it will get bitter & over extracted coffee
- Level but don't compress the coffee
- as soon as you get gurgling take it off the heat and pour
I already do all those, but I'm slightly unsure on the grind.
Finer grinds are used for proper espresso machines, is this because the higher pressure can properly take advantage of the closer pressing?
