Fitting an SSD into Antec P180
29 Apr 2004
I'm thinking of splashing out on a nice new SSD around xmas time but having had a quick look in the case I can't see how it could be mounted.
Has anyone managed to do this?
As solid state component without moving parts SSD doesn't generate any vibrations so you could attach it to case in any way you want.
Cheers, I might take the tape route as reading around indicates that the screws needed to attach drives to the P180 cage are too big to fit into the 2.5" to 3.5" adaptors (or some similar issue).
Mine's just resting loose in the bottom of my case. Doesn't vibrate and doesn't get hot so no need to mount it tbh.
I like these!
