HT Leads
20 Jun 2005
Derby
Hiya,
Should I get a shock from a HT lead if I wiggle it on the coilpack while the engine is running?
When I mean wiggle I just mean move it about on the coilpack, not anywhere near pulling it off
I've got a slight misfire problem on my car and am thinking it could be dodgy HT leads.
Cheers
Jon
HT lead shock, NICE, not something i would want to be zapped by.
No, sounds like the insulator has broken down.
ht lead shock can be very dangerous, ie potentially fatal!
get a new set, its something that could very easily cause a misfire
I think, although theoretically possible, it'd be a fairly extreme case if you died as a result - but I know all to well how much it hurts.
I'd be looking for new leads, but one way you can test is with a water spray bottle, something that gives off a misty spray - and spray it all around the coilpack at night - its likely that you'll then see where its sparking to. It's probably worth giving that a go, as last time I experienced this, it was due to a fine crack on the coilpack casing (Typical VAG coilpack, really)
I'll try this :)
would WD-40 be ok to spray?
bah, been sparked plenty of times hasnt done me any harm.
although my pee is now aqua-blue. :confused:
:p
seriously though asides from a shock and a sore limb then its pretty harmless although i almost wet myself once when i got hit by a saab pack on a self burn off cycle.
Certainly sounds like you need HT leads.
yeah, HT high tension, i think youre looking at hundreds of thousands of volts lol
what car is it?
As said, it's not the volts, it's the current.
Older coils (like >10 years ago, and stuff with a distributor) are usually 1A (fully on current in primary winding), they would be a lucky shot to kill you.
The very latest stuff has multiple 32A coils, and when the insulation fails there's a light show under the bonnet. These will very easily kill you.
30kv is about the maximum you'll get from most ignition systems.
upto 110kv now for many new coil on plug types.
diesel common rail injector wiring has actually killed more though, the wires run 200v at 20A and have took out a few of the unsuspecting who simply unplugged them while the engine was running to try and track down missfires.
