SSD what you recommend for under £120?
15 Nov 2008
Scotland / Blairgowrie
Im finally deciding on splashing my money out on a SSD. Iv got a WD 640gb 32mb cache hd atm and its takeing around 11 seconds to start up windows :(, after hearing ssd cards can start up windows in around 6-7 seconds i might deciding on buying one. Iv only got £120 to spend, so what do you recommend? Size doesnt matter, i only want it to start my OS which i will somehow transfer onto it. I say bigger the better but in this case i just want speed.
Recommendations ?
i had this in mind Corsair Extreme X32 32GB 2.5" SATA-II Solid State Hard Drive
I would say save up because if you get a 32Gb SSD you going to be really annoyed when you notice how much space Windows 7 takes up and you have none left! save a little and get a 64Gb SSD... but I wouldnt bother with a 32Gb SSD
Stelly
+1 for Vista or Windows 7, you need a minimum of 64gb SSD, unless you install Everything else on the old HDD, as 32gb will not be enough for either and your Programs...
after reading i think i might wait a while :P i always thought 32gb would be enough just for an operating system (windows 7). I was planning on having a mega fast drive ( SSD ) to load my OS faster, and have maximum ammount of room in my old HD for all my games. My old pc had 2 160gig hard drives and i hated it. To much swapping around and it got noisey.
If im recommended to save ill save. My build is finished so my money is going to stack up for a couple of months. I might just go for a 128gb, When it comes to the time ill have a look then, might be abit cheaper and more variety in size.
Can anyone explain why SSDs are so expensive?
Mine's just arrived, fitting at the weekend
Windows 7 takes up 12GB as a bare minimum. That leaves 20GB for applications, games, documents, Windows updates and etc.
OK true you could put everything on a standard SATA HDD, but why pay £100 or more when most of the stuff you use on your OS will be on a slow HDD anyway? Awesome your OS loads in 7 seconds and Notepad opens up a wormhole to a parallel dimension it loads so fast. Now load up your favourite application sat on your standard HDD and oops, still waiting as usual.
So if you're gonna blow over £100 quid on an SSD I would wait for at least 64 or 128GB.
Having said that, its just my thoughts on the matter since I would want almost all my apps on an SSD to make it worth having. Justing waiting for them to be cheap enough so my wallet doesn't protest! :D
I spend £120 on 3 F3's and get at max 368MB/sec with 1.368TB storage
But still the same slow mechanical access times, no matter how many drives you throw into your raid it doesn't touch an SSD for a desktop drive.
You're 3p33n has now shrunk huh.
OP - Crucial M225 64GB even though they have gone up you might be able to find one ~£120 somewhere....very good drives.
Performance is great. It's not quite as lightening quick as the 80GB X18-M in my desktop system, but still hugely fast compared to the 500GB HD that was in there before. Pleased as punch with it really, I'm actually debating whether to buy another one for my second desktop or squeeze out the extra cash for another X18-M.
