*** Official Call of Duty: Modern Warfare 2 Thread ***
Fair play if anyone legitimately manages to rack up a 25 kill streak. Should be rewarded with one hell of a perk.
Most I can get is around 5-6 in a row in a good session. Rest of the time its get a kill, get shot, respawn, rinse and repeat. :D
same here. its what makes the game so addictive, same with cod4. every kill feels like an achievement:p
Rare yes, impossible no. I've got 16 so far quite easily. With the more powerful kill streak bonuses it really wouldn't take much to get 25 kills, just a bit of luck. By luck, I mean not dying whilst controlling the predator/chopper/ac130 etc etc.
i was sitting with WA2000 ,Silencer,Hearbeat sensor and the scope stays on the rifle.I was getting loads of headshots,it only is good with silencer on hardcore tho.
I think it does but remember, you only get 3 kill streak bonuses so if you were on your 3rd you won't get any more. Also, if you die when the harriers or whatever are wiping out enemies your streak will reset.
I was also playing domination at 3am this morning,and some guy had 71 kills 20 deaths,and about a min befor end of match he dropped a nuke.I got xp for radiation sickness
One option they should have given was to join a game in progress or not. There's nothing worse than being lone or in a small group and being dropped into a game 140-0. Over the last two days soulja and I have been whacked into those types of games more often than not. :(
