I bought an Akasa northbridge + southbridge cooling set and used the small heatsink and fan that came with that... Had to take a dremel to it though to get it to fit!
Just got my ML115, very impressed by the build quality, a nice compact unit.
What version of ESXi should I download? I have installed ESXi to the internal USB (a very straightforward process) but it seems ESXi 4 (VSphere) is free on a evaluation basis only.
I had the exact same error when trying to install Windows Home Server (WHS).
For me it was related to the supplied hard drive. I put in a different boot drive and all was well. If you've got a spare hard drive I'd give that a go!
Has anyone installed Vista x64 on one of these ?
I can install Windows 7 x64 not problem, and it runs beautifully, but Vista 7 x64 blue-screens when it starts to copy files, an error with nvstore.sys - i.e. the nvidia drivers
Seems to be a common problem
http://forums13.itrc.hp.com/service...47627+1257894767481+28353475&threadId=1254975
I'll have to wade through that and see if there is an answer there
My daughters run Vista Business Ed. x64 no problem. I don't remember having to do anything special though I may have changed the SATA disk mode to turn off any possibility of RAID interfering.
I take it you pressed F6 when the DVD installation started and supplied your own SATA drivers?
-Pete
You're right, installing onto a different drive and it installs perfectly
Perhaps Vista install routine doesn't like that small 100MB system partition on the supplied boot drive ? Maybe deleting that would make it install onto that drive
Just picked up a HP P400 Raid controller for £45 delivered BARGIN!!!
Glad you got it sorted anyway.
