- 14 Jul 2005
- Bristol
Have many people here done any mods to their controllers?
Reason I ask is yesterday I decided to do the LED mod on mine...with the use of a crap soldering iron, some noncey tweezers and me being slightly hamfisted I stuffed the controller (used a spare one that was worn and horrible to test out the mod on).
I managed to remove the contact patch that solders the LED onto the PCB, only way I know to redo that is to dip it in solution that applies it (what I had to do when I stuffed up my GCSE Electronics coursework
I also received some black sticks and D-Pad today which I've fitted to my main controller and now it looks much better...
I will be spraying the grey bar black too when the weather isn't wet and horrible (can't do it inside really spray can fumes and paint will go everywhere
) as I really dislike the grey parts.
All the 'special' controllers...Resi, Halo etc. have black sticks and d-pad as well as the bar being black...but you can't buy the shell parts, so I have to spray mine...well, you can buy them, but at £10 for a nasty shell when I only want the bar section, I'd rather spray mine.
I will do the LED mod (changing from green to blue) at some point soon, but first I need to get a decent soldering iron (needle point rather than the normal angled one), some decent tweezers and a desk magnifying stand thing.
The LEDs are about 1.5mm long, .5mm wide and 1mm high, which makes it great fun when you drop one on the carpet.
Anyone else done any form of modifications to their controllers (bar SF4 ones)?
)I also received some black sticks and D-Pad today which I've fitted to my main controller and now it looks much better...
) as I really dislike the grey parts.All the 'special' controllers...Resi, Halo etc. have black sticks and d-pad as well as the bar being black...but you can't buy the shell parts, so I have to spray mine...well, you can buy them, but at £10 for a nasty shell when I only want the bar section, I'd rather spray mine.
