Modern Warfare 2 - HELP FOR NOOBS THREAD.
Loving this.
Found it a bit difficult at first, but reckon playing the maps a couple of times though get you your bearings while levelling to around 10+ starts to get you some decent guns.
Found my biggest problem is the kickback i was getting with the standard weapons, the SCAR helped a bit then i unlocked a weapon around level 10 or something which is cracking apart from it eats ammo and runs out quickly. Wish i could remember its name...
Find getting the red dot on asap a massive help as well. The perks system is easy enough to understand, its not too dissimilar to the old system, what i find pointless is the riot shield, can you not shoot at the same time as using it?
If you run out of ammo quickly, get the scavanger perk, will allow you to resupply from the dead, as it drops an ammo bag which you run over, very fast and easy to get the pro version of it as well.
Might be worth my while cheers.
Looking forward to the cold blooded perk, being invisible to people on the display, seem to get caught by a lot of people with it; camping away in their little gay corners. :mad:
Maybe try a combination of cold blood and ninja? ninja stops you showing up on the heartbeat monitor which is getting comming, seen a few ppl use it now, in the last couple of days.
Edit: Perks are unlocked at certain lvls just like weapons
I use Cold-blooded Pro and Ninja Pro on pretty much everything now. It's extremely useful against people that rely exclusively on their heartbeat sensor or thermal scope.
Ah I was wondering why some people didn't show up on the thermal scope, that explains it :p
People keep banging on about this Bling. It lets you have 2 attachments per gun, what two would you use that makes it so great?
Apart from some sort of scope what else is beneficial?
rp2000
rp2000
Heartbeat Sensor & ACOG/RDS/HoloSight is extremely popular for assault rifles. Thermal Scope & Silencer seems to be a sniper favourite on Hardcore.
rp2000
I'll be using Acog with Silencer, and now to the real reason of my post, rp, how did you get your own picture in that sig? I have to choose from a list of premade ones..
Thesnipergecko "did" it for me http://forums.overclockers.co.uk/showthread.php?t=17948755 (read last page)
Also, please turn off your voice changer on your PS3 headset, I connected to a U2 lobby you had a couple of weeks back and it was the most annoying thing ever :p
rp2000
Little guide from me, posted in the other thread, might help some of you who are struggling with kills.
Setups:
M16A1 with (Bling/Pro Perk: FMJ, Silencer or Redot/Holographic)
Perk 2: Stopping Power/Pro
Perk 3: Hip Fire Accuracy
or
M16A1 with FMJ
Perk 1: Sleight of Hand or Scavenger
Perk 3: Hipfire Accuracy
= One shot one kill (in 90% cases, only exception is if someone is shot in the lower torso, aim for chest area, done!
if your not Level 40 yet for the M16A1, use the Famas, this about 75% worth of shots kill first time.
If your using SCAR-H use:
SCAR-H with FMJ (i dont really use red dot, or holographic, iron sights is good enough!)
Perk 1: Scavenger (enough pickups gives you 10k experience in no time (little tip, if you see a scavenger pack, shoot your gun, reload and walkover, do this as much as you want and it will class it as a pickup, this way you'll get experience quick, and never run out of ammo!)
Perk 3: Hip fire accuracy
As for Perk 2/: i always recommend using stopping power, as it makes no end of difference, enemys fall a lot quicker.. therefore one shot kills are easier due to 3 shot burst fire. As for Hip fire i also never change this perk due to the fact we cant always aim down our sights, and this makes the gun a lot more accurate in close ranges/medium range full on gun fights.
For all setups too for Secondary Weapon: I always carry a Stinger (very handy because not too many people do, and its very effective against Air Attacks, the only time you will run into problems is if your against an AC130 (Takes 3 Stinger Missiles to Destroy, Because of Flares, Obviously you have 2, but in most cases you will die from an AC130, so you will get chance to take one down), or Heavy Helicopter Assaults (These also deflect using Flares)
The stinger is for airbourn vehicles only. I'll also add the bonus of carrying a Stinger is you can get decent exp depending on the vehicle you shoot down. for example:
UAV: 50 Points (No Defense, No Problem Taking Down)
Harrier: 200/300 Points (No Defense, No Problem Taking Down, Just make sure the turrent isnt in your direction)
Attack Helicopter: 200/300 Points (No Defense, Problem Taking Down, Same as above just have cover)
Pavelow: 200/300 Points (No Defense, Same as above)
Heavy Attack Helicopter (not sure of name): 300/400 Points (Abit more tricky to take down, i've had the odd problem, i believe flares are used)
AC130: 400 Points (The daddy of Airbourne attacks, read above)
If you are 50, I recommend using the Javelin as you can take out airbourne assaults, and also any landscape areas to take out multiple foot soldiers, NOTE: the Javelin only has one shot per life, so use it wisely! my i add also for the javelin, it fires forward and upwards, so if your firing make sure you do not fire in buildngs, unless your pushed against a wall looking out a window ;)
Not level 40 yet so will have to try the SCAR-H later on, I am using the M4 at the moment.
I see a few peeps using the stinger, 2 questions
a) what level to get it?
b) how many XP for blowing up the airborne stuff?
My sleight of hand is Pro already so may start developing Scavenger now.
rp2000
rp2000
Updates in my post, im not sure of the level, its not too high, what level are you now?
EDIT: level 30 for stinger :)
I'm level 26 or so, will need to work on that, but I reckon at least a few days before I hit 30 :(
rp2000
I just got the stinger - I love it. Watching the little rocket track towards its target and then KABOOM! Heheehhe.
