Just means you have lots of spare time.
You should reach max prestige fairly soon then
You need to put your console in the DMZ on your router, so it essentially is outside of the firewall.
Google whatever your router is and 'NAT' and Xbox.
just completed this on veteran , but it only says 85% complete?
think i've found it, xbox ip is 192.168.2.4 so just stuck that in DMZ and hope for the best - can't try it yet as the missus has taken over the telly for Corrie![]()
is the intel hidden in the missions as i did'nt find any , but then i was'nt really looking for it as i was'nt aware of any?
cheers
Yea, there are like 45 hidden laptops![]()
31 seconds for the pit run. Bah thats with 120% accuracy![]()
Jesus
i gave up and coudnt get it lower than 50 seconds
what guns do you use ? couldnt find a combo that i dont need to spend too much time reloading with.
104%?![]()
