I'm going to be buying a new TV today or tomorrow and I think it's going to be the Toshiba 32AV615DB.
I guess I'll get the ball rolling by asking if this is a good choice?
The thing that's going to matter the most to me is the ability to connect my PC to the TV. Only problem is that I'm not quite sure what cables I should be buying. Should I be looking for a DVI to HDMI converter and then buying a standard HDMI cable? As for the audio, would a "3.5MM Stereo Jack To 2 x Phono RCA Cable" be suitable?
I also read that it doesn't matter if you buy a cheapo HDMI cable. Would I be safe to just buy one from the bay then?
Or am I completely mad and going to order the wrong stuff?
Any help would be greatly appreciated, thanks!
and audio is running a 3.5 stereo jack from my audigy card to 2 phono jacks on the amp, cable was also a few pounds off the net
