- 8 Mar 2006
- Telemark
Hi,
You can get Genesis 6x9 subs (http://www.incarexpress.co.uk/view_product.php?partno=GENP69018) and whilst not having the same level of bass that you would get from a proper sub they are far better than nothing and would fit but are also not that cheap.
They will sound flat if you don't have anything else:
Freq. response is 35Hz - 500Hz. You hear 20Hz through 22kHz, they need something else on both sides, particularly above.
