I can't work out which to go for (Or the varients of each).
The C2D E6300 has a 1066 FSB, but runs at 1.8ghz and tops out at about 2.6ghz from what I've read, and it's also 65nm.
The PDC E5300 has an 800 FSB, but runs at 2.6ghz and tops out around 3.4ghz, and uses 45nm?
Which would be the better one to go for?
(Be aware there are two E6300, they have the same spec apart from one is core 2 duo using 65nm, and the other is pentium dual core using 45nm, the only other difference being that the C2D is 1.8ghz stock, and the PDC is 2.8ghz stock).
Its a newer chip, runs cooler, faster clock speed and will overclock better
