2 Dec 2009 at 12:33 #1 tres tres Soldato Joined 16 Oct 2007 Posts 7,493 Location UK I have an Acer AL1716, and it has a stuck/dead pixel. What's the difference? It's bright blue rather than black..
2 Dec 2009 at 13:04 #2 derkaderka derkaderka Permabanned Joined 30 Jun 2009 Posts 433 Location NI Black = Pixel is stuck in off mode and will never switch on again Bright Blue = Stuck Sub Pixel (blue one) is stuck hard on
2 Dec 2009 at 14:02 #3 raralis raralis Associate Joined 24 Sep 2008 Posts 643 Location London / Belfast You might be able to fix the lazy/stuck pixel. Try massaging gently that area on the screen and check if it starts changing colours. You can also run an application that changes colours rapidly; this should sort of force the pixel to work and hopefully get fixed.
2 Dec 2009 at 16:12 #4 tres tres Soldato OP Joined 16 Oct 2007 Posts 7,493 Location UK Great, thanks guys. Although will make sure no one's around when I start massaging the screen
2 Dec 2009 at 16:16 #5 Delboy Delboy Soldato Joined 10 Sep 2003 Posts 2,814 tres said: Great, thanks guys. Although will make sure no one's around when I start massaging the screen Click to expand... I don't think he means for you to light some candles and get the baby oil out.
2 Dec 2009 at 19:25 #6 Hathaway Hathaway Associate Joined 17 Jan 2009 Posts 236 Delboy said: I don't think he means for you to light some candles and get the baby oil out. Click to expand... Surely it can't hurt?
2 Dec 2009 at 20:13 #8 alex24 alex24 Soldato Joined 1 Jan 2008 Posts 11,579 I had a look on a search engine and I found this. It might help get rid.
