on the graphics menu at the side its displaying 29fps on the wall. Is that it?
I have cloth and crowd detail on max as well.
Thats a bit low for your spec..? Mine displays 66fps and the benchmark max is 71fps.
My Spec is in my sig.
I run the game at ultra settings but its not consistently smooth. Anyone else the same with a top spec?
Looks great though![]()
I'm using a wheel, not sure if it is easier/harder than a pad, bet makes it great fungame runs excellent, good arcade fun!
Anyone using a steering wheel for this? I'm thinking it will be a lot easier with the pad, am i wrong in thinking this?
I can't even get into the damn game. Gets to the AMD splash screen, plays it and then it turns black. Sometimes after a while it turns white but eventually it bombs out to windows but it doesn't fully recover - does the turn to basic mode and keeps going to a black screen then back to windows and is pretty much totally unresponsive until I finally restart my compy. Only once has it gotten to the Intel splash screen after the AMD one but it bombed out halfway through playing that.
W7 x64 Pro
i5 750
ati 5850 - 9.11
4GB DDR3
Tried running as admin, through steam, not through steam, XP compatability, pretty much everything I can think of and get no where.
Any ideas?
Its awsome game aswel, beats NFS Shift hands down, cos with Shift, theres no room for error at all.
I assume you've all been able to enter your names?
I've signed into Live and all that, but creating the in-game profile, I can change my nationality and Gender, but don't seem to be able to change my name away from 'Player One'? Pressing enter over it makes the 'select' noise, but there's no way to delete what's already there/enter my own name?
I hope I'm not doing something too stupid :3
Nope, I had the same problem. It's something to do with the GFW Live integration.
I had to just go with the default name, and then later in the settings you can rename your profile.
yeah, had to restart game with wheel unplugged, then change controls back to wheel defaultsI fixed it by unplugging my G25 and restarting the game, could enter it all fine then, weirdly.
But got into a race and couldn't use the wheel, despite plugging it in >_>
GfWL strikes again!
game runs a lot better with v sync on for me, get a lot of tearing with it off
