- 15 Feb 2009
- Bristol
I tried the 'I cut my own hair' thread recently or whatever it was called but didn't get any answer.
Basically i'm thinking of getting my own clippers and cutting my hair myself to save money and convenience in the long run. I have a v cut with grade 1.5 on the sides. Usually my barber cuts the top and back with scissors but using the clippers should give the same result?
So looking for good hair clippers that can do 1.5 (or just 2 if 1.5 isn't usually an option), and maybe a trimmer? (for the sideburns?).
Not looking to spend a huge amount but want a decent one that will last me and is easy to use for a first time experience.
Thanks.
Thanks.
