I find the quoted picture as a pure imagination of someone with a great fantasy.
1) if Globalfoundries would have 28nm process done, they wouldn't do their CPUs in 45nm process and wouldn't bother with TMSC 40nm process. If they will have it by end of next year or in 2011, call yourself lucky. 40nm process is what we will have next year.
http://www.pcgameshardware.com/aid,698957/AMD/Ati-28-nm-Radeon-chips-from-Globalfoundries/News/
2) 384 bit bus. Yes, right, and you know that one about ...
. AMD and 384 bit bus with that core size is not going to happen.
3) The 5890 have less transistors, yet more shader cores ?
Sorry, but that whole picture looks like "Hm, make some nice numbers which will be quoted all around the world".
Those changes are way too big for a AMD half cycle (plus AMD half cycle is going to happen sometimes at end of Q2 2010/start of Q3 2010 - read june-august).
Firstly yes, its incredibly unlikely any of the info is accurate, its certainly possible those are the specs for the 28nm part/refresh but Q1 is incredibly unlikely.
However you need to realise several things about the rest of what you said.
CPU chips are made on a vastly more expensive SOI process, which is far harder to produce, takes far longer to change the process and redesign the core for a process shrink and doesn't tape out quickly. It takes a year, no less, for Intel or AMD to tape out a design and push it into mass production. Current 40nm gpu's, even if only one shader cluster and vastly reduced heat out put could not come close to 2Ghz, let alone 3-4Ghz, the processes aren't compatible, not remotely comparable, you could very easily be making a 28nm gpu and a 45nm CPU on different processes.
Anyway, 28nm bulk will be easier to produce and should come much earlier than 28nm SOI process, likewise the 32nm dates(which most likely will be skipped it seems to go directly to 28nm as 32nm is shaping up to be crap all around without HKMG, which again seems a waste at 32nm), are for the new fab being built, what GloFo decide to do with their other fabs is up to them.
384bus with a core that size? I have no idea what you mean, core size has entirely nothing to do with the amount of bandwidth it needs. Yes bus width increases pin out, traces required and complexity of the pcb, transistor count and a little more power, theres entirely no reason to not do it based on core size. The question is, does the extra cost warrant the performance, to fit onto a 5850 which should eventually be £150, no, to be on an ultra overclocked high end £300 card, very possibly, considering it would still be cheaper than a Fermi and could still make more profit while possibly being faster, why not.
Infact, if they ditch all gddr3/4 support in an upcoming chip gddr5 actually allows some very fancy memory timing, right now every memory chip has to have the exact same length trace from gpu to memory chip, meaning every chip has some ridiculous trace routing that add's layers, cost and complexity. GDDR5 allows the controller to stagger the signals so the traces can be different lengths, ie as short as physically possible. Meaning extra bus width doesn't add anywhere near the cost as it would have a year ago with older memory, meaning a much smaller bump in pcb cost, production time and even amount of metal used for traces.
That list also has the 5890 with 400million more transistors, not less, which would more than account for a minor shader bump and extra memory controller space.
however again, the list is just wrong, there will not be 28nm available right now, no fab in the world is doing real chips on 28nm in risk production let alone mass producing it, its simply not there or available.
Also the bump in shader numbers looks like the classic crap from last gen where someone convinced half the internet based on reading a picture of the 4870 core INCORRECTLY, that there were extra shaders built in for redundancy, that wasn't the case, it won't be the case here either. A new core could certainly bolt more on, and on a smaller process no doubt will. But AMD will not drop from 40nm to 28nm, a FULL node drop in 4 months and add 20% in shaders, that will never in a trillion years happen.
Not least because no manufacturer has dropped a full node before in anything under 2 years and seeing that TSMC is the least reliable manufacturer on the planet right now, just nonsense. Now keep in mind that in general both Nvidia/AMD have added anywhere from 80-100% more transistors on a HALF NODE drop in manufacturing process, a 28nm version of this 5890 would be, just ludicrously small, like, less than the size of a current 5770 probably. You'd be expecting a roughly doubling of transistors every half node drop on GPU's, yet this is what 20% more on a full node.
You'd expect on a similar architecture a 32nm "5870" style chip to have anything around 4billion transistors, and a 28nm version to have 6-8billion transistors, not 2.5billion.
