GTX 380 & GTX 360 Pictured + Specs
bru
bru
21 Oct 2002
kent
Or you could just buy an AMD card today and enjoy something which kicks everything Nvidia ACTUALLY produces right in the nuts.
Just a suggestion.
something to kick nvidia in the nuts as you put it would so you be sugesting a 5970 then.
if you are then the phrase you was looking for was pre order today get in a unditermined length of time, not buy today........:D:D:D:D:D:D:D
and dont say you can get it elseware because your not suposed to mention competitors.....:p:p:p:p
11 Sep 2007
from the internet
Or the 5870, seeing as the GTX295 is completely out of stock here. :o:o:o:o
Caporegime
6 Dec 2005
Birmingham
Couple of HD5770s to be honest. Obligatory over use of smilies.
6 Oct 2007
North West
5970 reccomended PSU from Guru3D.
The card requires you to have a 600 Watt power supply unit at minimum if you use it in a fairly high-end system. We assume you'll overclock your processor and that draws a lot of extra power. That power supply needs to have (in total accumulated) at least 50 Amps available on the +12 volts rails.
Hardly nuclear reactor status.:rolleyes:
11 May 2008
UK
that is total system at the outlet ;) but definitely more than the ATi cards, although I'm sure the 4xxx series cards drew more power than the 5xxx do
