There used to be 26 cars on the track and only 6 points positions.
That was down to 26 from mid 30's in pre-qualifying at times.![]()
even with budget cuts I would still suggest its more expensive now adays compared to when you are thinking about (and F1 prize fund is much greater) - so therefore more percentage of the grid deserve to get a cut (otherwise stronger teams just get stronger and smaller teams disappear after a few years - where is the incentive to even try and enter F1?)
edit - I like the new scoring system - certainly should push more to try and get 1st instead of 2nd - but as pointed out above the tail end has to be sorted out, as the gaps between the points doesnt really make sense
