The New Cases Gallery
Tsunami dream, too poor for a new case, but I still love her:)
Side panel fan updrade is most effective thing i've done to it
looks very nice, and certainly nicer than my TJ07 but the only thing I'd say is I think you have your CPU block a bit wrong, you should always have the outlet higher than the inlet so it'll bleed properly.
Other than that its very tidy :)
How are the Xigmitechs on the rads? thanks
23cm fan, to thermaltakes credit its made really well, you can see large ball bearings meaning on shutdown its still spinning long after the other case fans (tho obv its larger and has more momentum) but I like watching it spin down:)
Moves loads of air and doesn't add to system noise. Gotta get rid of amber intake fan and replace with one last smoke ultra quiet, amber is so noisy!
Thanks mate, all the watercooling guides I had read all said the same thing that you have, but in the instructions for the Heatkiller it says that the inlet is the one that I have used..
I doubt it will cause much if any issues, I am really delighted with my temps so far, they are a LOT better than high end air!!! :)
I really like the Xigmatek fans, I have them hooked up to my Scythe Kaze Master Ace, and usually keep them running around 800 to 1000RPM, and at that speed they are fairly quiet to my ears..
Another vote for Xigmatek here as well...
I have 8 of the running at 4volts.. more than adequate to cool my rads
4v to 12v only gives me 1*C difference.
If your rads are good, 800rpm is really all you need
First time i have tried a tidy case normally its wires everywhere, still got a bit of tweaking to do inside but happy with the result.
Had the camera out today so i thought id show some pics of my new rig :)
Feels great to get that old M-atx mobo out of my antec 1200 :P. Not a new case but a lot of new parts inside (Mobo, RAM, CPU and cooler).
Im dead happy with this rig and so many thanks to you guys for the inspiration :D.
love it i have the 900 and it seems a bit cramped really want this case now!!
